Better way to delete rows
Solved2.26K views22nd November 2024protocol.DeleteRow rows
Sergio Suarez [SLC] [DevOps Member]123 1st August 2024 1 Comment
Currently, the driver is deleting a part of the total rows at once, which is taking too much time and causing an RTE to pop up. We have already logged the times and the amount of rows to be deleted:
As you saw, the amount of rows to be deleted is over 50,000.
The way we are doing it is:
protocol.DeleteRow(Parameter.Cmqamdschannels.tablePid, keysToRemove);
My question is if there is another way to delete rows so it won’t stay a lot of time doing it.
Thanks.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd November 2024
Edib Šupić [SLC] [DevOps Enabler] commented 2nd August 2024
Hi Sergio,
since you are removing all rows, would protocol.FillArray with empty array speed things up?
frans siew [SLC] [DevOps Advocate]1.08K Posted 6th August 2024 2 Comments
Hi Sergio,
There isn’t any faster way (at least that I can think of) to remove keys other than repopulating the table or clearing all keys like Edib or Michiel has mentioned.
if the intention is to avoid going into RTE when deleting rows, maybe you can delete them in smaller chunks to avoid the DeleteRow from taking too long. example deleting in groups of 5000 rows.
Sergio Suarez [SLC] [DevOps Member] commented 15th August 2024
Hello Frans,
I already tried that, and even with 5000 rows it is taking more than 8 minutes
frans siew [SLC] [DevOps Advocate] commented 16th August 2024
I see that the initial attempt took about 15mins so there is definitely an improvement with the smaller amount of keys.
If I am not mistaken the SLProtocol/SLNet calls should not exceed 15K rows at a single time. so could you try adjusting try increasing/decreasing the keys to see if you can get better results.
if that still does not help, maybe check with software
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 2nd August 2024 1 Comment
Hi Sergio
When you want to clear the entire table, the most efficient would be to use the Action clear in the XML: clear | DataMiner Docs
If you are in a QAction, you can call ‘protocol.CheckTrigger(id);’. Then have a trigger with that id that triggers that Action. This way you don’t need to retrieve all the keys in the QAction.
Sergio Suarez [SLC] [DevOps Member] Posted new comment 5th August 2024
Sergio Suarez [SLC] [DevOps Member] commented 5th August 2024
Hi Michiel,
I think I wasn’t clear with my question. I am not trying to delete all rows nor clear the full table; I am trying to delete some rows.
As you can see in the screenshot, the number of rows obtained is the total of the rows in the table, while the number of rows to be deleted is less than the first value.
Sorry for the misunderstanding.
