Best way to retrieve elements that are using a certain connector
Solved2.78K views6th July 2023Connector DMS elements
Ana Pinho [SLC] [DevOps Member]1.42K 5th July 2023 0 Comments
Is there any fast and optimized way to retrieve the elements on a DMS that are using a certain type of connector?
I know that we can retrieve all the elements present on the DMS.
Just wondering if we have a call that does the filtering already 🙂
Thank you,
Ana
Ana Pinho [SLC] [DevOps Member] Selected answer as best 6th July 2023
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 5th July 2023 0 Comments
Hi Ana,
Would you be using this in Automation, a protocol or the dashboards?
e.g. in automation, you can just use the engine.FindElementsByProtocol function.
engine.FindElementsByProtocol("NMOS IS-05","Production");
Ive Herreman [SLC] [DevOps Enabler] Answered question 5th July 2023
