Best way to export alarms per protocol in Dataminer
Solved1.51K views13th July 2023alarms
Bruno Sousa [DevOps Member]669 24th January 2022 0 Comments
Hello
What is the best way to export alarms by protocol in Dataminer?
Thank you.
Best regards
Bruno Sousa
Bruno Dias [SLC] [DevOps Member]2.39K Posted 24th January 2022 0 Comments
Hi Bruno,
That’s possible by adding a new tab in your alarm console and apply a filter for ‘Protocol’:
This will show you all active alarms that are coming from elements running ‘Ericsson RX8200’ protocol with Production version. The same is possible for history alarms.
Another way to quickly check on active alarms is to add a new column to see the Protocol name and sort it by this field:
Both ways will end up with a list of alarms in your alarm console that you can easily export by selecting all rows and right-click and select ‘Copy’ or just drag-n-drop your selection to a notepad or spreadsheet file.
