BACnet integration for DataMiner
Solved721 views10th September 2026adl2099 BACnet driver info IoT
Alberto De Luca [DevOps Enabler]5.96K 25th August 2026 0 Comments
Hi Dojo - while documenting future integration scenarios, I've come come across a device exposing data over the BACnet protocol [UDP port 47808 - ASHAE Standard 135-2024 (SSPC 135) / https://www.iso.org/standard/92057.html ]
Would this be something for which a "Generic BACnet" DM protocol could be created, rather than a device-specific driver?
This standard is not an IETF one, it has some similarity to SNMP - but ISO standardized.
This is how I'm currently mapping the concepts around it:
SNMP: Agent + MIB → OIDs → GET/SET
BACnet: Device + PICS(*)/object model → Objects/Properties → Read/WriteProperty
(*)PICS stands for:
Protocol Implementation Conformance Statement (seems similar to a MIB to me)
It's essentially a manufacturer's declaration of what BACnet functionality their device implements
Given that a Generic SNMP was implemented in the past, I'm just looking for advice if an attempt for a Generic BACnet could be viable - anyone aware of any BACnet integrations already done in DM?
Thanks
Alberto De Luca [DevOps Enabler] Selected answer as best 10th September 2026
Thijs Vanovenacker [SLC] [DevOps Advocate]2.75K Posted 4th September 2026 2 Comments
Hi Alberto,
Thank you for your question.
We have implemented BACnet communication in DataMiner connectors before, so we can confirm that BACnet-based integrations are technically feasible and that successful polling of BACnet devices can be achieved.
Regarding a generic BACnet connector, the approach is certainly conceivable, similar to how a Generic SNMP connector exists today. However, from a user experience and maintainability perspective, we generally recommend implementing connectors around the functional intent of the device or solution being integrated.
A fully generic approach typically lacks the domain-specific context that enables richer visualisation, alarm handling, and operational workflows. This is comparable to generic SNMP integrations, where alarms and data are available, but their meaning and context are often less clear to operators.
We'll reach out to discuss your specific scenario and explore the most practical way forward.
Alberto De Luca [DevOps Enabler] Edited comment 10th September 2026
Alberto De Luca [DevOps Enabler] commented 10th September 2026
Thanks for your feedback Thijs – marking as solved.
Please, do you know if any of the connectors previously implemented are also available in the catalogue?
I agree it will make sense to customize the integration for the specific device, but at this stage I was more curious about leveraging the "auto-discovery" features where devices from different vendors may co-exist in the same ecosystem.
Not my exact scenario, but in the context of generic building automation, something like this: (where parameters of interest for each unit are likely going to be "temperature", "humidity" of the room and so on)
BACnet/IP network: UDP 47808 / BAC0
branch1 e.g. Distech ECY-PTU (Vendor A) –> BACnet objects
branch2 e.g Siemens controller (Vendor B) –> BACnet objects
branch3 e.g. Honeywell controller (Vendor C) –> BACnet objects
I understand that similarly to a MIB in SNMP, we may need specific BACnet PICs from each vendor – so when I get these I'll be in touch via our TAM.
Thanks
