Automation script – Output to user
Solved1.48K views23rd January 2025
Stefan Schedletzky [DevOps Advocate]2.76K 20th August 2024 1 Comment
I have an automation script which is showing a result for example in the information events. But what is the best way to show the user the results from the script? Is it possible to show a text field, a message or something else?
I don't want to create a file or something. It should be straight forward, you execute it and get the results directly in front of you.
Stefan Schedletzky [DevOps Advocate] Selected answer as best 23rd January 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
Hi Stefan,
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the answer (using the ✓ icon)?
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 20th August 2024 4 Comments
Hi Stefan - this recent announcement is probably relevant for you:  Introducing the Interactive Automation script component - DataMiner Dojo
Stefan Schedletzky [DevOps Advocate] commented 20th August 2024
Hi Ben,
this is only available in LCA. Before I wanted to do something in Dashboards, this is not possible. So I just want to execute in the script just in Cube and show the result.
Also not available in main release.
Ben Vandenberghe [SLC] [DevOps Advocate] commented 20th August 2024
The best way to give feedback to a user when they run an automation script is then probably to make it an interactive automation script. Or is that not desirable for your use case?
Gelber Mahecha [SLC] [DevOps Enabler] commented 22nd August 2024
Hi Stefan,
As per your comment about executing the script in Cube and showing a result, apart from an interactive script as Ben suggests above, you could also pass the script’s output to a session variable that can be presented in a visual overview card.
This is explained here: https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/linking_shapes/Linking_a_shape_to_an_Automation_script.html?q=executesessionvariables#passing-automation-script-output-to-session-variables
