Automation script C# SshClient Namespace reference
Solved4.05K views23rd April 2021Automation script namespace reference SSH sshclient
Daniel Ralls157 23rd April 2021 0 Comments
I am trying to send an ssh command with C# but I’m getting an error for the SshClient. What namespace reference do I need so that it is accepted? Do I need to install Openssh on the Microsoft server?
I’m open to other suggestions if you have a better way to send a command. It’s a very simple script:
using (var client = new SshClient(“IP”, “username”, “password”))
client.Connect();
client.RunCommand(“the command I’d like to run”);
client.Disconnect();
Daniel Ralls Selected answer as best 23rd April 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 23rd April 2021 0 Comments
Hi Daniel,
You could use the library sshnet (Renci.Sshnet).
You will need to copy the DLL to the folder C:\Skyline DataMiner\ProtocolScripts
More details about how to reference DLLs can be found in DataMiner Help – Adding Csharp code to an automation script
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 23rd April 2021 0 Comments
Hi Daniel,
You will need to install the SSH.Net nuget package and add a reference to the Renci.SshNet namespace by adding “using Renci.SshNet;” on top of your script.
Depending on your requirements, it might be more useful to move your SSH communication to a driver. More information on this can be found in our development guide here.
Ive Herreman [SLC] [DevOps Enabler] Answered question 23rd April 2021
