Automation Memory Files dropped values after 10.1 upgrade
Solved3.01K views29th March 2022Automation memory file upgrade
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 21st March 2022 1 Comment
After the upgrade all Automation Memory files have dropped their values.  These are empty now.
Is there any way to get them back without rolling back?
Are these located in a file that can be found in a backup file or in the recycle bin?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 29th March 2022
Jeroen Geldhof [SLC] [DevOps Enabler] commented 21st March 2022
We found that slnetclienttesttool can still read the values correctly.
A task has been created for further investigation on why Cube can’t read the values.
Kevin Vermeulen [SLC] [DevOps Member]552 Posted 21st March 2022 0 Comments
Perhaps setting the files back from C:\Skyline DataMiner\Scripts\Memory would work?
Kevin Vermeulen [SLC] [DevOps Member] Answered question 21st March 2022
