Automation Memory Files dropped values after 10.1 upgrade
Solved2.90K views29th March 2022Automation memory file upgrade
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 21st March 2022 1 Comment
After the upgrade all Automation Memory files have dropped their values.  These are empty now.
Is there any way to get them back without rolling back?
Are these located in a file that can be found in a backup file or in the recycle bin?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 29th March 2022
Jeroen Geldhof [SLC] [DevOps Enabler] commented 21st March 2022
We found that slnetclienttesttool can still read the values correctly.
A task has been created for further investigation on why Cube can’t read the values.
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 25th March 2022 0 Comments
Hi Jeroen,
I took the chance to connect to that system.
I noticed that 10..0 and 10.1 Cube were installed on the system.
Removing 10.0 Cube and clearing XBAP, opening 10.1 Cube. Everything works fine now.
Assumption confirmed: 10.0 Cube had DLL conflicts with 10.1 server, which results in the weird outcome in the client.
-1
Kevin Vermeulen [SLC] [DevOps Member]552 Posted 21st March 2022 0 Comments
Perhaps setting the files back from C:\Skyline DataMiner\Scripts\Memory would work?
Kevin Vermeulen [SLC] [DevOps Member] Answered question 21st March 2022
