Automation: How can we know a given element is really up and running in Dataminer?
Solved2.18K views15th December 2023automation scipt DMS
6
Paulo Henriques [SLC] [DevOps Advocate]1.96K 13th December 2023 0 Comments
I'm writing an automation where I need to start a given set of elements that are stopped.
The script needs to wait until all the elements are effectively up and running and not just we triggered their start.
On a first approach, I'm testing the IsActive property but I believe it gets 'true' as soon as we call Start(), thus the method below does not really do what we want.
Do you have any ideas on how to achieve this from my automation script?
ps: the logic for the stopping case will also be requierd, i.e., to wait for all the elements that I called Stop(), are really stopped.
private bool IsAllStarted(Element[] elems)
foreach (Element el in elems)
if (!engine.FindElement(el.DmaId, el.ElementId).IsActive)
return false;
return true;
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 15th December 2023
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 13th December 2023 1 Comment
Hi Paulo,
Although the approach of Matthias might work, it uses an SLNET call so we should be cautious when using these. Another option that might be worth mentioning is using the following method Method IsStartupComplete | DataMiner Docs, part of the Skyline.DataMiner.Core.DataMinerSystem namespace (available through a NuGet package).
Kind Regards,
Jarno
Guilherme Gaspar [SLC] [DevOps Member] commented 13th December 2023
To complement Jarno’s answer, which I believe it’s the correct approach; IsStartupComplete method is a wrapper for a specific call and you can find additional information about it here: https://docs.dataminer.services/develop/api/NotifyTypes/NT_ELEMENT_STARTUP_COMPLETE.html
