Automation: delay on parameter set
Solved2.91K views18th July 2023Automation delay
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 6th May 2021 0 Comments
We have noticed that performing actions on elements (i.e. setting parameter value) via the automation scripts takes considerably longer time than usual, especially the automation scripts for controlling  our satellite uplinks.  (usually it took 10 seconds to complete script commands and now it could take over a minute).
Is it possible that the DMA which the automation scripts are run on is approaching its limits (almost 1000 elements) and hence the latency during setting parameters? The way I understand it is when an automation script wants to set a parameter on an element a separate thread is created by that element which is then added to the execution queue of the SLProtocol and the script waits until the set parameter thread is executed.
I remember reading somewhere in the documentation that the automation scripts are run on the agent on which the script was created (or uploaded to) and regardless of which agent the client executing the script is connected to. Is this correct?
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 7th May 2021 0 Comments
Hi Jeroen,
When you make a set parameter from an automation script (using cube is equal) that set needs to wait until no group is being executed in your element. Your element should be constantly polling stuff, so it ends up delaying your sets.
Jorge Dias [SLC] [DevOps Enabler] Answered question 7th May 2021
