Arista switch port /. ARP monitoring
Solved1.57K views23rd January 2025
Juan Chavez514 15th August 2024 0 Comments
Hello DM community,
Im trying to create a dashboard, either dataminer dashboard, low code app to monitor / display status for an Arista switch. Id like to get a visual for Port status "up/down? and ARP reply. Is there free off the shelf protocol I can test Any help greatly appreciated!
Miguel Barquet [SLC] [DevOps Advocate]2.00K Posted 19th August 2024 0 Comments
Juan,
I suggest you contact your technical account manager to request a trial of the Arista Manager connector. This robust connector will give you access to everything you want to know about Arista switches.
Moreover, there is a use case Arista Manager Connector - DataMiner Dojo. You could also deploy the Arista Manager solution package, which may already contain something similar to what you are trying to build.
Your technical account manager can provide further assistance.
Regards
