Are there DataMiner connectors based on IP88-D audio routing protocol?
Solved1.62K views11th July 2023IP88-D
Thomas Gunkel [SLC] [DevOps Enabler]1.23K 19th March 2021 0 Comments
Are there existing DataMiner connectors using (Wheatstone) IP88-D audio routing protocol?
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 22nd March 2021 0 Comments
Hi Thomas,
At the moment of writing, there is no off-the-shelf integration available.
You can check our catalog with available integrations through the dataminer services platform.
DataMiner can be integrated with any product from any vendor, irrespective of the interface or protocol required, and irrespective of whether that is proprietary or standard.
Checking the datasheets available on the Wheatstone website, I could find that they have an SNMP mib to interface with these systems. I'm not sure if there are any other APIs available.
If you have the manual for these systems, we could have a look at these and see if we can find any more information there. Alternatively, you can reach out to your systems supplier or vendor to see if there is an API available.
