Are there any existing integrations between DataMiner and ServiceNow products?
Solved3.24K views10th July 2023integrations IT ServiceNow
Reinout Daels [SLC] [DevOps Member]787 12th August 2020 0 Comments
Are there currently any existing integrations (in either direction) between DataMiner and ServiceNow products, for example creation of tickets in ServiceNow ITSM for certain DataMiner alarms?
Koen Annys [SLC] [DevOps Advocate]144 Posted 12th August 2020 1 Comment
There are 2 Driver integrations for Vendor ServiceNow which might contain what you need. I suggest looking into these.
ServiceNow ServiceNow
ServiceNow Tables
Jochen Dewachter [SLC] [DevOps Member] commented 12th August 2020
“ServiceNow ServiceNow” driver was built with a custom API specifically for DataMiner (developed by Silver Storm). It’s a web service listening for incoming updates on what is called an ‘incident’ in ServiceNow and a ‘problem’ (=maintenance window). It’s not actively polling tickets from ServiceNow. It should also be able to create new incidents into ServiceNow.
