Append method for Interactive Toolkit
Solved1.73K views3rd June 2024
Aditiben Desai [DevOps Member]382 18th January 2024 2 Comments
Hello,
I am working on UI Interactive toolkit to display different parameters. I want to know is there an append method that I can use incase if there are multiple (key,value) pairs for the same parameter. I have created a dictionary which stores multiple key value pairs , now I want to display all of those values using interactive toolkit. How can I do it?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 3rd June 2024
Ive Herreman [SLC] [DevOps Enabler] commented 19th January 2024
Hi Aditiben,
What UI component would you like to use (a label, dropdown, other)?
Do you want to show all values in one UI component, or display a distinct component for every value?
Aditiben Desai [DevOps Member] commented 19th January 2024
I want to use normal text as sometimes dictionary has only one key,value pair and sometimes its more than one. If thats more than one then i want it to display all key value pairs in different lines as a text.
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 19th January 2024 2 Comments
Hi Aditiben,
To show all values in a dictionary you could use the DropDown component.
  • Create the dropdown control and add it to the UI:
var dropdown = new DropDown();
dropdown.Options = new[] { "Option 1", "Option 2", "Option 3" };
dropdown.Selected = "Option 1";
  • Retrieve the selected option:
string selectedOption = dropdown.Selected;
In the same way you can also use CheckBoxList and RadioButtonList.
I want to use normal text as sometimes dictionary has only one (key,value) pair and sometimes its more than one. If thats more than one then i want it to display all key value pairs in different lines as a text.
Tom Waterbley [SLC] [DevOps Enabler] commented 22nd January 2024
If you want to combine the values in a dictionary and show them as text, you could use the String.Join method as follows:
Dictionary dict;
MyLabel.Text = String.Join(“, “, dict.Select(x => x.Value)); The result is a single string with commas between the values.
