Alert sound output
Solved2.94K views8th September 2023
Gunter Pillasch33 6th September 2023 2 Comments
Hi
I get a voice alert every few minutes from the dataminer. Is there a way to turn off this output?
Thank you!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 8th September 2023
Bert Vandenberghe [SLC] [DevOps Enabler] commented 6th September 2023
Is that voice alert like a text to speech thing? Which text is being read out? Or is it just an alert sound?
Gunter Pillasch commented 6th September 2023
It is a text to speech, but this option is not active in the alarm tab settings.
Gunter Pillasch33 Posted 6th September 2023 2 Comments
Hi @all
Many thanks for the help.
The "Audible alert" option is greyed out for me.
Marieke Goethals [SLC] [DevOps Catalyst] commented 8th September 2023
Could you check if you have the necessary rights to modify this option? You can find information about this here: https://docs.dataminer.services/user-guide/Basic_Functionality/Alarms/Working_with_alarms/Working_with_the_Alarm_Console/Configuring_a_custom_alert_sound_for_an_alarm_tab.html?q=audiblealert
Gunter Pillasch commented 8th September 2023
I installed the newest version and that solved the problem.
Thank you.
