Alert sound output
Solved3.00K views8th September 2023
Gunter Pillasch33 6th September 2023 2 Comments
Hi
I get a voice alert every few minutes from the dataminer. Is there a way to turn off this output?
Thank you!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 8th September 2023
Bert Vandenberghe [SLC] [DevOps Enabler] commented 6th September 2023
Is that voice alert like a text to speech thing? Which text is being read out? Or is it just an alert sound?
Gunter Pillasch commented 6th September 2023
It is a text to speech, but this option is not active in the alarm tab settings.
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K Posted 6th September 2023 0 Comments
Hello Gunter
Can you check if you have the audible alert option enabled?
It can be found in the hamburger menu in the alarm console.
If it's not that, there is also an option in there "Text To speech", perhaps this is one enabled?
Timothy Van Poucke [SLC] [DevOps Advocate] Edited answer 6th September 2023
