Alarm “timeout” severity and SNMP forward
Solved2.88K views6th July 2023alarms SNMP Timeout Alarms
Bruno Sousa [DevOps Member]669 13th April 2023 0 Comments
Hello
Can you please tell how can we how can we differentiate the “timeout” severity from others (critical, major, minor, etc.) when we send “timeout” events from Dataminer to a 3rd party system via “SNMP forward” ?
Thank you.
Best regards
Bruno Sousa
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 13th April 2023 0 Comments
Hi Bruno,
Not sure if this is what you are looking for but the severityID of the timeout alarm will be 17. This way you can differentiate the timeout alarms from the other alarms.
Bruno Sousa [DevOps Member]669 Posted 14th April 2023 0 Comments
Thank you both for the suggestions!
Best regards
Bruno Sousa
Bruno Sousa [DevOps Member] Answered question 14th April 2023
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 14th April 2023 0 Comments
Hi Bruno,
A possible option is to configure a SNMP Manager with:
  • A different binding OID (a custom OID that you know represents a timeout alarm)
  • A filter that only accepts alarms with ‘Timeout’ severity
Below an example of the trap forwarded:
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 14th April 2023
