Alarm details from automation script
Solved2.20K views11th July 2023alarm details Automation script
Pedro Sánchez [DevOps Advocate]325 7th November 2022 0 Comments
Hi all,
We are trying to get some details from an alarm but we are having some problems when the alarm is already closed. In fact, we need to retrieve the "Close time".
We tried using engine.GetAlarmProperty(DMAID,ALARMID,"AlarmTime") but also the SLNET message GetAlarmDetailsMessage(DMAID,ALARMID)
Do you know a method to get that time and other properties from already closed alarms?
Thank you in advance,
Kevin Vermeulen [SLC] [DevOps Member]552 Posted 8th November 2022 3 Comments
Hi Pedro, you could take a look at GetHistoryAlarmsMessage call? When it's closed normally it's then a history alarm.
Pedro Sánchez [DevOps Advocate] commented 8th November 2022
Hi Kevin, thank you very much!
Do you know any example or documentation for that call?
Kind regards!
Kevin Vermeulen [SLC] [DevOps Member] commented 8th November 2022
GetHistoryAlarmsMessage ham = new GetHistoryAlarmsMessage();
ham.DataMinerID = element.DMAID;
ham.HostingDataMinerID = element.HostingDMAID;
ham.time = time;
GetHistoryAlarmsResponse hamResp = engine.SendSingleResponseMessage(ham) as GetHistoryAlarmsResponse;
Also, I would like to warn using slnet calls, these could change in the future. If the engine class as described in the help lacks functionality, a new feature request could be done. Please contact your person within Skyline or add a feature suggestion here: https://community.dataminer.services/feature-suggestions.
Miguel Obregon [SLC] [DevOps Catalyst] commented 8th November 2022
Hi Pedro,
Please also have a look at the answers of a similar question:
https://community.dataminer.services/question/how-to-get-history-of-alarms-in-a-protocol/?hilite=GetHistoryAlarmsMessage
