Alarm Console – Double Click Action to open EPM Card
Solved1.57K views23rd November 2023Alarm Console
Jarno Lernou [SLC] [DevOps Enabler]6.08K 20th November 2023 0 Comments
When using the Topology component in an EPM Environment, we have the possibility to open dedicated cards to open a certain EPM object (e.g. Street, Amplifier, Node, etc.).
In the Alarm Console, we can navigate to that card by adding a custom hyperlink and making it open the card we want. However, I would like to make this the default action when double-clicking. Right now, it opens the Backend Manager element which is not really desired. It does show the ‘in-Visio’ topology, but we would like to make use of the new functionality with dedicated EPM Cards.
In the ‘user settings > Alarm Console > Alarm double-click action’, the value is defined as ‘Open element card’.
Jarno Lernou [SLC] [DevOps Enabler] Selected answer as best 23rd November 2023
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 20th November 2023 1 Comment
Hi Jarno,
I just double checked the code and it seems that the ‘Open Element Card’ setting first checks if it is an EPM object. If so, it should open the EPM object otherwise it will open the element. You can still create a ticket so we can investigate why the Cube is not opening the EPM object.
Jarno Lernou [SLC] [DevOps Enabler] Posted new comment 23rd November 2023
Jarno Lernou [SLC] [DevOps Enabler] commented 23rd November 2023
Hi Michaël, thank you for the confirmation. There was an issue with the connector and now this is fixed.
