Add Comment to an Alarm
Solved1.50K views18th January 2024
Aditiben Desai [DevOps Member]382 10th January 2024 0 Comments
Hello,
I am trying to add a comment to an active alarm using API call. The comment gets updated in the comment column but when I pull Alarm details after adding comment, the comments doesn't show up in alarm details.
Looking for possible solution to this.
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th January 2024
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 11th January 2024 0 Comments
When adding a comment, a new alarm (with a new alarm ID) gets created. This new alarm has the same root alarm ID of the previous alarm. Using the root alarm ID you can call the GetAlarmHistory API method to get the alarm ID of the most recent alarm, and then call GetAlarmDetails with this alarm ID, this response should include the comments.
