Just as table templates brought visualizations to the next level, we are now excited to introduce two upcoming features that will reshape how you interact with the DataMiner web apps: the ability to clone low-code apps and duplicate GQI queries. These additions put the power of customization and efficiency firmly in your hands, allowing you to work smarter, not harder.
Cloning low-code apps: A new level of convenience
New to Low-Code Apps? Even without the latest update, this module provides an extensive array of customization options, empowering you to create applications without the need for coding skills. These custom apps seamlessly interact with data from a DataMiner System, offering a unified interface to visualize and manage your devices.
Explore real-life use cases of low-code apps that have proven to significantly boost work and time efficiency:
Up until now, duplicating these highly valuable apps posed a challenge. However, recognizing the undeniable advantages of repurposing apps for similar needs without creating new ones each time, DataMiner introduces a cutting-edge feature starting from version 10.4.1. With this advancement, you can effortlessly duplicate low-code apps with just a few clicks, saving valuable time and making the entire customization process feel like a breeze.
Witness the simplicity of duplicating an app and getting started in mere seconds:
Duplicating GQI queries: Efficiency at your fingertips
Our commitment to simplifying your workflow extends beyond duplicating low-code apps. With the release of DataMiner 10.4.1, we are excited to introduce the ability to duplicate queries.
Have you crafted a query that you wish to reuse with minor modifications? Say goodbye to the complexities of manual duplication and welcome the convenience of timely access to your data.
Regardless of whether you’re a seasoned pro or new to the game, this new feature simply feels intuitive. Take a look:
Both new features share a common objective: enhancing your productivity within the DataMiner platform. They empower you to:
- Save time: Perform tasks in a fraction of the time it used to take.
- Customize without hassle: Tailor your apps and queries with ease, without starting from scratch.
In conclusion, with the brand-new query and Low-Code App duplication features, DataMiner empowers you to further elevate your productivity. You can effectively leverage, reuse, and repurpose your past work, or kickstart projects using the extensive DataMiner Catalog. Take the first steps toward efficiency today.
