Writing an unit test for methods using SRMManager helpers
Solved1.79K views12th July 2023programming srmmanagers Unit Test
Maxim Bouckaert [SLC] [DevOps Member]169 8th September 2022 0 Comments
Hey Dojo-community
I was wondering if there is a way to test functions that do calls to one of the SRMManager helpers.
Is there a way to mock this? Or will this result in having to write the code in an entirely different way?
Just as an easy example, how to test the following function:
public Resource[] ExampleFunction()
return SrmManagers.ResourceManager.GetResources(ResourceExposers.Name.Equal("test"));
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 8th September 2022 0 Comments
Hi Maxim,
If you want to mock data from the server, then it is advised that you mock via an interface and create separate test class of the interface.
Example:
interface ISRMHelper which has method "Resource[] GetResource(string name)
class SRMHelper : ISRMHelper. This is the class used in production code.
class TestSRMHelper: ISRMHelper. This is the test class for testing ISRMHelper.
production code could be like this:
ISRMHelper _helper;
public bool CheckOnResources()
string elementName = this.Element.Name;
var resources = _helper.GetResources(elementName);
return resources?.Length > 0;
Implementation of GetResources
in production: return SrmManagers.ResourceManager.GetResources...
in test: anything you want, such as returning object from a dictionary<string, Resource>
You can then write unit tests and do calls like "var hasResources = myManager.CheckOnResources();".
You can mock the outcome and check if the code works in your production code.
Hope this helps you further
