WorldCast Systems Audemat DAB Probe trap alarm
Solved845 views23rd January 2025
Pedro Domingues [SLC] [DevOps Advocate]12 30th August 2024 0 Comments
When we receive a trap, in the trap receiver qaction we are updating a table with the alarm value.
is it possible to create the alarm with the timestamp we receive in the trap?
Miguel Obregon [SLC] [DevOps Catalyst]22.42K Posted 30th August 2024 0 Comments
Hi Pedro,
In this case, the best approach is to update the 'Root Time' column rather than 'Time' column. In that way a user can distinguish between:
  • When the alarm was raised in the DMA
  • When the event was triggered from the device
In order to set the root time with a timestamp you will need to use history sets. See the answer from this question for additional information.
Hope it helps.
