Workspace with docked filtered alarm tabs that use sliding window & keep active alarms
Solved907 views11th September 2025Alarm Console Cube keep active alarms sliding window workspace
Ramunas Milcius [DevOps Advocate]188 10th April 2025 1 Comment
Hi all, has anyone been using such combo successfully yet?
My use case is a Cube client running on a machine that feeds onto a screen with content from the dataminer workspace.
This workspace has a few alarm tabs that were undocked from the Alarm Console and been docked into the workspace.
Those alarm tabs are using saved custom filters with range of sliding window and keep active alarms enabled.
All seem to work but this workspace not keeping active alarms enabled for the sliding window after the Cube client sign out and re sign-in.
In the meantime these filtered alarm tabs continue working as expected in the Alarm Console..
Screenshot #1: alarm tab setup
Screenshot #2:workspace with filtered alarm tab before the Cube session sign out
Screenshot #3:workspace with the same filtered alarm tab after the Cube session signed out and sign in
Ramunas Milcius [DevOps Advocate] Selected answer as best 11th September 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 11th September 2025
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 10th April 2025 0 Comments
Hi Ramunas,
The option “Keep active alarms” is not saved correctly when you save the alarm tab in a workspace. I have created a task so we can provide a fix.
