Working Automation Script Error
Solved1.39K views4th April 2025#automationscript
edward.smith@fox.com Smith200 11th February 2025 3 Comments
This is a follow up question that is related to a previous solved question.
For context, I have the script working on a Lab DMA with no errors. I exported the script and then imported it on another system, and it works beautifully with the exception of throwing this error. When you click "OK" after the confirmation dialog, it makes the changes very quickly, then pauses for a few seconds and generates this error.
It behaves the same whether I launch it directly from the automation area, a Visio in Cube, or from the Visio on the monitoring web interface.
edward.smith@fox.com Smith Selected answer as best 4th April 2025
Miguel Obregon [SLC] [DevOps Catalyst] commented 11th February 2025
Hi Edward,
Have you tried disabling the option 'After executing a SET command'
https://docs.dataminer.services/user-guide/Advanced_Modules/Automation_module/Running_Automation_scripts/Script_execution_options.html
edward.smith@fox.com Smith commented 11th February 2025
This is what I have on the button: Script:webclick||dmaID=19**51;elementID=6;parameterNumber=155;tableIndex=f4b749d8-5794-4b19-bce8-81fe1af17134;parameterValue=2|||NoConfirmation,CloseWhenFinished
Are you suggesting adding an additional instruction after CloseWhenFinished?
Hi Edward,
Yes, can you try adding 'NoSetCheck'?
More information here:
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/linking_shapes/Linking_a_shape_to_an_Automation_script.html#options
Jorge Dias [SLC] [DevOps Enabler]5.31K Posted 21st February 2025 1 Comment
Hi Edward,
If you use engine.SetFlag(RunTimeFlags.NoCheckingSets); in your script then it should work always.
// Existing code script
edward.smith@fox.com Smith Posted new comment 4th April 2025
edward.smith@fox.com Smith commented 4th April 2025
This cleared the error through the web execution of the button
