Will the SDN Controller solution work with the Evertz 3080IPX
Solved799 views6th July 2023
Randy Ulvenes [SLC] [DevOps Member]1.23K 29th March 2023 0 Comments
If it does work are these the the connectors that would be required: Evertz IPX2080, SDN Controller, Generic Matrix
Any specific Visio files?
Steven Soenens [SLC] [DevOps Member]444 Posted 5th April 2023 0 Comments
Hi Randy,
Mastering Media Operations requires indeed an SDN component (but also control surfaces, resource management, resource control and automation, databases to document incoming lines and signal, flow monitoring etc etc). You are probably referring to flow engineering? This component is indeed new and part of the DataMiner core, and required a specific adaption to the connector. Today, we have done this for our IS-05 connector, Arista MCS and also SDI matrix. We have low code apps to manage flows in addition to the well-known matrix visio of course. OK?
