Will the Automation script C# code reference be extended for DataMiner apps?
Solved2.75K views14th October 2020Automation jobs ticketing
Kevin Vermeulen [SLC] [DevOps Member]552 1st October 2020 0 Comments
Currently, you can do various things with the C# code reference. Getting an parameter from an element etc.
What I'm missing for the apps that are available, Ticketing, Jobs etc. to also have methods provided(Create Job, Edit Job, Delete Job, Create JobDomain), (Create Ticket, Create TicketDomain) etc..
Internally we have solutions for this, but perhaps such methods as above could general be available for customers and supported through the official DataMiner help.
Kevin Vermeulen [SLC] [DevOps Member] Selected answer as best 14th October 2020
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 1st October 2020 0 Comments
Hi Kevin,
You can make use of the helper classes to achieve this. An example of a helper class can be found in topic Unable to use the ResourceManagerHelper
In your case you need to add following namespaces in the C# code:
  • JobManagerHelper: Skyline.DataMiner.Net.Jobs
  • TicketingGatewayHelper: Skyline.DataMiner.Net.Ticketing
Jens Vandewalle [SLC] [DevOps Advocate] Edited answer 1st October 2020
