will start an already started timer cause trouble?
Solved1.61K views7th July 2023protocol SLProtocol timer
Mark Miao74 9th March 2023 0 Comments
Hi:
I have an action which periodically starts an timer. So the action will try to start an already started timer every 10 sec. Will that cause a trouble in dataminer engine?
Thanks
Laurens Moutton [SLC] [DevOps Enabler]9.93K Posted 9th March 2023 1 Comment
When verifying the protocol development checklist, that can be downloaded here, there is mentioned in chapter 3.5.4.4 Starting/Stopping Timers:
  • The use of conditions must always be favored over starting, stopping and restarting timers, but a condition on a group is favored over a condition on a timer, since the timer performs a regular check on that condition to see if it becomes true. In case an action is used to start or stop a timer, a timer that is already started must not be started again, as this could lead to issues.
Regards,
Mark Miao commented 9th March 2023
Thank you very much for the help
