Will restarting SLPort processes have consequences on a production system?
Solved2.52K views14th July 2020SLPort
Alex Johnson [SLC] [DevOps Advocate]921 13th July 2020 0 Comments
Is it possible to just restart SLPort processes without having to restart the DMA? Will that be harmful on a production system?
We have SLPort that is stuck listening to TCP 514, and we are wanting to restart the process(es) to try and fix the issue:
Alex Johnson [SLC] [DevOps Advocate] Selected answer as best 14th July 2020
Laurens Moutton [SLC] [DevOps Enabler]9.93K Posted 14th July 2020 5 Comments
The SLPort process can’t be restarted, if you stop this process then it will trigger a full restart of the DMA. See SLWatchdog2 logfile:
2020-07-14 07:45:01 14372|-> Process with PID 15016 (SLPort.exe) stopped.
2020-07-14 07:45:01 14372|Queueing FULL DataMiner Restart in 2 minutes (SLPort.exe)
Matthijs Favorel [SLC] [DevOps Advocate] Posted new comment 16th July 2020
Wouter Demuynck [SLC] [DevOps Advocate] commented 14th July 2020
As additional info:
These processes can be restarted without fully restarting DataMiner:
– SLScripting
– SLASPConnection
– SLAutomation
– SLScheduler
– SLAnalytics
(these will be registered as a process disappearance by SLWatchDog though)
Laurens Moutton [SLC] [DevOps Enabler] commented 14th July 2020
Be careful when restarting such a process.
In the past I was restarting SLScripting processes to recover from a deadlock situation, but these restarts were “counted”.
Later there was a real process disappearance of SLProtocol and because the SLScripting processes got restarted, the conclusion was not to automatically restart the DMA, leaving it in a strange state with elements that don’t have an SLProtocol process anymore. Something like this:
2020-07-14 09:49:41 2700|-> Process with PID 21696 (SLScripting.exe) stopped.
2020-07-14 09:49:41 2700|Remove Threads(0) (SLScripting.exe) succeeded.
2020-07-14 09:49:41 12964|–> Added process watch for PID 5424 process SLScripting.exe (Reset allowed)
2020-07-14 09:49:41 2700|–> Process 5424 SLScripting.exe registered
2020-07-14 09:50:26 14372|-> Process with PID 19212 (SLProtocol.exe) stopped.
2020-07-14 09:50:26 14372|Stopping restart timer (more than 2 processes stopped)
Should be better since RN26440 [10.0.10/10.0 CU5/9.6 CU17], which makes sure the agent does restart in this scenario.
Alex Johnson [SLC] [DevOps Advocate] commented 14th July 2020
Thanks for the info! We have decided we will have to arrange a test window to restart the DMA.
Matthijs Favorel [SLC] [DevOps Advocate] commented 16th July 2020
Although restarting the SLASPConnection process won’t cause an automatic DataMiner restart, it might cause issues in some specific reports, so it’s not advised to restart it on a live system. (ref Task 73627)
