Will HTTP/1.1 429 Responses automatically send an Element into Timeout?
Solved2.06K views7th July 2023
6
Michael Wells [SLC] [DevOps Member]502 30th January 2023 0 Comments
Leander Druwel [SLC] [DevOps Member]2.11K Posted 30th January 2023 2 Comments
Hey Michael,
Not an expert on this matter, but based on this article, it will depend on the element timeout time and how the other HTTP sessions are answered.
The article describes a case where the element does not go into a timeout state, because the total time of not having responses is lower than the configured timeout time. If other request would keep on providing that same reply, the element would go in a timeout state.
So, at least from how I would understand, it depends on how many responses with HTTP/1.1 429 are returned in a row, i.e. if that exceeds the element timeout time.
Leander Druwel [SLC] [DevOps Member] Posted new comment 31st January 2023
Michael Wells [SLC] [DevOps Member] commented 30th January 2023
If I understand you correctly then, if you have 3 429’s returned in a 5 second time window, and then a 200OK returned 15 seconds later, if the device timeout is set to 30 seconds, then the element will not go into timeout at all?
Leander Druwel [SLC] [DevOps Member] commented 31st January 2023
That is correct, so similar to any other communication protocol in DataMiner. A timeout alarm is generated against the element timeout time that is set.
