Will HTTP/1.1 429 Responses automatically send an Element into Timeout?
Solved1.99K views7th July 2023
6
Michael Wells [SLC] [DevOps Member]502 30th January 2023 0 Comments
Jeroen Neyt [SLC] [DevOps Advocate]2.61K Posted 30th January 2023 0 Comments
Below you can find the logic that is applied to timeout handling in terms of HTTP status codes ranges:
  • 2XX: No timeout
  • 3XX:
    customRedirect enabled and the redirect is not properly handled: Timeout
    customRedirect disabled and the redirect is properly handled: No Timeout
  • 4XX: Timeout
  • 5XX: Timeout
As a result 429 Too Many Requests will automatically put the element in timeout if the last retry of the configured amount of retries on that connection still results in a 429 Too Many Requests or another one in the timeout range.
Leander Druwel [SLC] [DevOps Member]2.10K Posted 30th January 2023 2 Comments
Hey Michael,
Not an expert on this matter, but based on this article, it will depend on the element timeout time and how the other HTTP sessions are answered.
The article describes a case where the element does not go into a timeout state, because the total time of not having responses is lower than the configured timeout time. If other request would keep on providing that same reply, the element would go in a timeout state.
So, at least from how I would understand, it depends on how many responses with HTTP/1.1 429 are returned in a row, i.e. if that exceeds the element timeout time.
Leander Druwel [SLC] [DevOps Member] Posted new comment 31st January 2023
Michael Wells [SLC] [DevOps Member] commented 30th January 2023
If I understand you correctly then, if you have 3 429’s returned in a 5 second time window, and then a 200OK returned 15 seconds later, if the device timeout is set to 30 seconds, then the element will not go into timeout at all?
Leander Druwel [SLC] [DevOps Member] commented 31st January 2023
That is correct, so similar to any other communication protocol in DataMiner. A timeout alarm is generated against the element timeout time that is set.
