Will Arista Manager work with 7500 Series?
Solved2.39K views19th July 2023Arista DCS
Jacky Cheng [SLC] [DevOps Member]20 17th December 2020 0 Comments
Hello Community, did any master in this community have experience to the following models
  1. ARISTA DCS-7516N
It is a datacenter Class switch.
which i checked on Connector Catalog, Arista MGR is workable on 7010 and 7050 series.
Any master play with this switch in their project case?
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 17th December 2020 1 Comment
Hi Jacky,
The arista manager is compatible with all Arista switches running Arista EOS.
This means that the driver will work with the DCS-7516N.
Jonathan Triboulet [SLC] commented 1st March 2021
Just for the record in case other people are interested to know, the following models also run on EOS and would be compatible with the Arista Manager driver :
• 7010T
• 7020R
• 7280R
