Will a DM upgrade overwrite a newer DM Web Upgrade
Solved1.78K views16th March 2023upgrade
11
Matthijs Favorel [SLC] [DevOps Advocate]2.63K 16th March 2023 0 Comments
Will a DM upgrade overwrite a newer DM Web Upgrade?
For example, if I have a DM 10.3.2 with a 10.3.5 web upgrade, will installing a DM 10.3.4 package downgrade the web apps to 10.3.4?
Matthijs Favorel [SLC] [DevOps Advocate] Selected answer as best 16th March 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 16th March 2023 2 Comments
Hi Matthijs,
That’s a great question!
Yes, the full DM upgrade will override the web only update, even when the web update was of a higher version.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Posted new comment 16th March 2023
Baptiste Pattyn [SLC] [DevOps Advocate] commented 16th March 2023
I think it might be a good idea to make sure the most recent version stays on the system? Or do we expect compatibility issues?
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 16th March 2023
Web only upgrades are a brand new concept so there are definitely many optimizations possible. No compatibility issues are to be expected, just note that the web apps are backwards compatible and not forwards compatible (so running older web apps on a newer DMS is not supported).
