Wildcard in Element reference when Visio not linked to a View
1.93K views23rd May 2025elements link Visio wildcard
Nick Chirumbolo [DevOps Advocate]1.04K 1st August 2024 2 Comments
Is it possible to someway link a shape within a service Visio to an Element using a wildcard character, as described here:
  • Element name mask, service name mask, or service alias mask containing wildcard characters ("?" and/or "*").
    If wildcard characters are used, the shape dynamically refers to the first element in the view to which the Visio file is linked. If no element matches the name mask in that view, then the elements in the services and subservices in that view (and, if necessary, all subviews) are also checked.
Here is the current element tree (Numbered elements are Services):
  • UAT
    • UAT Playout
      • 601 - ... - Playout
      • 602 - ... - Playout
    • UAT Distro
      • 601 - ... - ... Distribution
      • 602 - ... - ... Distribution
The ... are human-readable labels that may change so they don't match. Also each service has a property containing the ID number (i.e. 601).
On the "UAT Distro" shape I tried this:
  • View: UAT Playout
  • Element: [Property:id_number] - * - Playout
As well as creating a group and moving the "View" field to the group level shape data.
Is there anything else that will work without having to strictly enforce matching labels?
Nick Chirumbolo [DevOps Advocate] Answered question 23rd May 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd November 2024
Hi Nick,
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the answer (using the ✓ icon)?
Nick Chirumbolo [DevOps Advocate] commented 22nd November 2024
This is still not working for me. I found a workaround, but it is not ideal. I will open a ticket and post the response here.
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 2nd August 2024 4 Comments
This feature was designed for this exact use case and should work exactly as you described: https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/linking_shapes/Linking_a_shape_to_an_element_a_service_or_a_redundancy_group.html#item-reference
Do note that if we find something else that matches the wildcard in the general view structure (or in an earlier service) you will need to use the ServiceContext to make sure you find the right one. It's in fact always good practice to do so.
Nick Chirumbolo [DevOps Advocate] Unselected an answer 21st May 2025
Nick Chirumbolo [DevOps Advocate] commented 2nd August 2024
Then why is it not working for me? If I write out the Element name without wildcards it links the shape, but if delete some characters and use a * the shape disappears from the Visio.
To note the Elements I’m trying to link to/from are Services, but they are not included in each other’s service (that would seem to create an alarm loop). Instead I was just trying to include them in the Visio drawing for navigation.
Toon Casteele [SLC] [DevOps Enabler] commented 5th August 2024
Hi Nick, that last part is not entirely clear to me. Maybe it’s best to reach out over mail to our technical support so we can sync closer on what the actual setup looks like.
Nick Chirumbolo [DevOps Advocate] commented 6th December 2024
To follow up, I found the issue is that wildcard Elements must be under the Visio drawing in the Surveyor tree. I'm trying to link between Elements in unrelated Views. I'll open a new question to ask about this.
