Why does my Cassandra DB Size BPA fail?
Solved1.82K views3rd June 2022BPA Cassandra
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 2nd June 2022 0 Comments
When trying to run the Cassandra DB Size BPA on my system I receive an execution failure. What can be the reason for this?
My system is configured as follow:
  • 1 Windows VM (DataMiner)
  • 2 Linux VMs (Cassandra & ElastichSearh)
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 3rd June 2022
Gellynck Jens [SLC]2.72K Posted 3rd June 2022 1 Comment
Hi Jens,
From the limitations on this page (at the very bottom) I understand that the BPA is limited to local Cassandra nodes only while I think your system is using a remote Cassandra. I think the BPA is correctly stating it cannot execute, but the error message should be made more clear.
Jens Vandewalle [SLC] [DevOps Advocate] Posted new comment 3rd June 2022
Jens Vandewalle [SLC] [DevOps Advocate] commented 3rd June 2022
Hi Jens, That’s indeed the case. I’ll follow this up with Create so that the message is more clear.
