Why do we need to use both partialSNMP and multipleGetBulk options together?
Solved1.22K views7th May 2025generic SNMP partialSNMP
Jason Wan [SLC] [DevOps Advocate]350 7th May 2025 0 Comments
Hi All,
I have some questions regarding the use of partialSNMP and multipleGetBulk options in SNMP table polling.
According to the documentation:
  • The partialSNMP option is described as: "When polling large SNMP tables, you can use the partialSNMP:x option to fetch only 'x' rows at a time."
  • The multipleGetBulk option is described as: "Gets the table contents, retrieving multiple rows at once."
I've seen configurations using instance;partialSNMP:X;multipleGetBulk:X, and I'm wondering why both options are needed, as they seem to perform similar functions.
Thanks!
Jason Wan [SLC] [DevOps Advocate] Selected answer as best 7th May 2025
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.28K Posted 7th May 2025 0 Comments
Hi Jason,
I believe multipleGetBulk is focused more on performance; as in how many rows are fetched per GetBulk request.
partialSNMP's focus is on reliability; as in even if one GetBulk fails or returns incomplete data, you tell it to keep going on - this way you might get some data instead of none.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Answered question 7th May 2025
