Why can’t display Source ID, Destination ID and other to table from MENU QUERIES for DCF connection.
Solved1.70K views31st May 2024
Jaroslaw Burtny [DevOps Member]756 17th January 2024 0 Comments
Hi All.
I don’t get parameters like Source ID, Destination ID and other …. to table from MENU QUERIES for DCF connection.
Where does Dasbord get these parameters or does it create them itself?
I can’t display these the parameters in ma table as below
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 31st May 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 17th January 2024 2 Comments
Hi Jaroslaw,
These parameters are defined in the elements that expose DCF interfaces. When you open an element that expose DCF connection, you should be able to see the DCF interfaces/connections in the page General Parameters-> DataMiner Connectivity Framework (Configure ..)
If the DCF Interfaces and connections are displayed in these elements, then they should be available in data source ‘Get DCF Interfaces’
and ‘Get DCF Connections’
In case they are not displayed in the Dashboard app, I would advise to contact techsupport@skyline.be. We will need to further investigate why these interfaces/connections are not displayed in your DMA.
Jaroslaw Burtny [DevOps Member] commented 23rd January 2024
Hi Miguel.
Big thanks for help, it’s solved a problem.
Br.
Jarek
Miguel Obregon [SLC] [DevOps Catalyst] commented 23rd January 2024
Glad to help!
Jaroslaw Burtny [DevOps Member]756 Posted 18th January 2024 0 Comments
Hi
The problem with DCF connection in dashboards is probably because I cannot initiate connections in menu GENERAL PARAMETERS ( Framework Connectivity)  for Element AppearTV X10 and BridgeTech VB 2220 as below
But in Element TMux Ateme I see these connection as below :
I can see only one Element ID 62202/7 (AteneTMux) with these parametres in dashboard :
How can I takes these parameters correctly on DMA and next to dashboard for DCF connection.
Is it somewhere in the driver? something needs to be marked in driver or a bad driver on DMA?
Br.
Jarek
Jaroslaw Burtny [DevOps Member] Answered question 18th January 2024
