Which connector for Arista 720XP leaf switches?
Solved1.28K views2nd May 2024Arista Connector
Jordy Bekaert [SLC] [DevOps Advocate]2.26K 2nd May 2024 0 Comments
Hello, would there be a connector available in the Catalog which can be used to monitor Arista 720XP leaf switches?
Jordy Bekaert [SLC] [DevOps Advocate] Selected answer as best 2nd May 2024
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 2nd May 2024 0 Comments
Hi Jordy,
You can use the “Arista Manager” driver (link) for any arista device running eOS (including the 720xp).
