Where can I get the ProtocolId for automation script?
Solved1.81K views13th July 2023Automation script
Bruno Sousa [DevOps Member]669 20th July 2021 0 Comments
Hello,
If we want to execute an automation script like the presented below (using API):
<DMAAutomationScriptDummy>
<Element xsi:nil="true"/>
<ProtocolName>Xicom Technology XTC-123</ProtocolName>
<Name>XYZ</Name>
<ProtocolVersion>XXX</ProtocolVersion>
<ProtocolId>????</ProtocolId>
</DMAAutomationScriptDummy>
Where can I get the ProtocolId?
Thank you.
Best regards
Bruno Sousa
Ive Herreman [SLC] [DevOps Enabler]14.80K Posted 20th July 2021 0 Comments
Hi Bruno,
In the protocolId field you need to specify the Dummy ID defined in the automation script.
You can get the ID for the dummies, from the automation script XML or by using the GetAutomationScript API call.
