Where are Component info & Key point stored in SQL
Solved1.97K views10th July 2023alarm properties MySQL
Alexander Verriest [SLC] [DevOps Advocate]702 7th October 2020 0 Comments
In Cassandra there are dedicated fields for Component info & Key point in the alarm table, but in SQL these fields are not present.
Where are these values saved there? Or are these always read from the information template at runtime?
Brent Alleweireldt [SLC]2.21K Posted 7th October 2020 0 Comments
These fields are not stored in MySQL. They are retrieved at runtime from the information template when an alarm is generated or Requested. SLElement will do this when an alarm is created or an open alarm is configured during element startup. SLNet will mostly handle the cases involving historic data.
In Cassandra these are stored in the database under the CI 'componentinfo' and kp 'Key point'.
