When does alarm focus icon appear?
Solved2.75K views11th July 2023alarms
Bruno Sousa [DevOps Member]669 4th May 2022 0 Comments
Hello
When does the alarm focus icon in the alarm console appear?
Do we need to enable the "incident tracking" feature to have this?
Thank you.
Best regards
Bruno Sousa
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 5th May 2022 0 Comments
Hi Bruno,
In addition to Ive his answer you don't need to enable the "Incident tracking" but you need to enable the "Alarm Focus" feature. You can find this setting in System Center => System settings => Analytics config
Michaël Pincket [SLC] [DevOps Advocate] Answered question 5th May 2022
