When does alarm focus icon appear?
Solved2.70K views11th July 2023alarms
Bruno Sousa [DevOps Member]669 4th May 2022 0 Comments
Hello
When does the alarm focus icon in the alarm console appear?
Do we need to enable the "incident tracking" feature to have this?
Thank you.
Best regards
Bruno Sousa
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 4th May 2022 1 Comment
The DataMiner Analytics assigns an estimated likelihood or “alarm focus score” to each alarm, after analyzing the short-term history and current behavior of incoming alarms. The alarm focus score is based on a combination of likelihood, frequency, and severity.
Likelihood scores are used to spot daily patterns. If an alarm occurs at the same time every day, it will be assigned a high likelihood value at that time.
Frequency scores are used to detect parameters that frequently go into and out of alarm or alarms that persist over a long time.
Depending on the focus score, an alarm can be considered unexpected. In that case, this is indicated with the Focus icon.
More details can be found in this section of the help.
Ive Herreman [SLC] [DevOps Enabler] Posted new comment 4th May 2022
Ive Herreman [SLC] [DevOps Enabler] commented 4th May 2022
P.S. It’s not required to enable incident tracking for this.
