What’s the difference between LiteElementInfoEvent properties IsDerivedElement and IsDynamicElement?
Solved1.59K views21st September 2021SLNet
Jens Vandewalle [SLC] [DevOps Advocate]10.00K 20th September 2021 0 Comments
Class LiteElementInfoEvent contains properties IsDerivedElement and IsDynamicElement. What's the difference between them?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 21st September 2021
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 20th September 2021 0 Comments
Hi Jens,
If I'm not mistaken, the derived element is exported from a redundancy group, where the dynamic element (a.k.a. DVE) is exported from a normal element.
