What’s the difference between dataminer.lic and response.lic?
Solved2.11K views2nd September 2020licensing
Jochen Dewachter [SLC] [DevOps Member]2.17K 24th July 2020 0 Comments
When requesting a license, I sometimes receive a dataminer.lic and sometimes a response.lic. What's the difference between the two?
Marieke Goethals [SLC] [DevOps Catalyst] Edited question 2nd September 2020
Jordy Bekaert [SLC] [DevOps Advocate]2.15K Posted 24th July 2020 0 Comments
We indeed have 2 different DataMiner license files:
DataMiner.lic file
This file is a permanent license file, which means not time-limited, and intended for production or staging agents.
Response.lic file
This file is a time-limited license file, mainly used for demo and testing purposes.
Jochen Dewachter [SLC] [DevOps Member] Selected answer as best 24th July 2020
