What would cause a DMA to take more than 1 hour “starting elements”?
Solved2.42K views14th July 2020Failover
Ryan Reuss [SLC] [DevOps Member]562 13th July 2020 0 Comments
MYSQL Failover system was upgraded from 9.0 to 9.5 CU12.
After upgrade, a manual failover test was initiated and attempted (3 times) to bring backup agent online (none successfully). Primary starts up very quickly.
SLDataminer log indicates the following:
Ryan Reuss [SLC] [DevOps Member] Selected answer as best 14th July 2020
Jan Vanhove [SLC] [DevOps Member]1.23K Posted 14th July 2020 0 Comments
This is typically caused by a large amount of offload files that exist on the 'backup DMA'.  This gets somehow confirmed by the following lines: 'Aborting open offloads...'.
Check in the following folder:
C:\Skyline DataMiner\System Cache\Local
If there are too many files, it might be interesting to understand why this specific folder holds a lot of files.  Possible options:
  • the connection towards the local MySQL DB is not good
  • there are elements generating a lot of data to be offloaded (trend or element data)
  • overload of alarm/information events
  • resource problem
