What versions of DataMiner do we need to use to work with ADFS + SAML for https and Cube connections
Solved397 views5th January 2026
Jaroslaw Burtny [DevOps Member]756 2nd December 2025 0 Comments
Hi All.
What versions of DataMiner do we need to use to work with ADFS + SAML for https connections and on which version does it work with the Cube client?
Big thanks for naswer.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th January 2026
Christine Kapembe [SLC] [DevOps Advocate]1.01K Posted 23rd December 2025 0 Comments
A ticket was raised for this enquiry, and guidance on the correct configuration was provided.
If you would like to configure SAML with ADFS, please refer to the following guide:
Configuring SAML with Microsoft Entra ID as identity provider | DataMiner Docs
You will need to configure the corresponding settings on ADFS as outlined in the documentation.
SSO is now working for both Cube and web apps.
