What is the meaning of “element alarm state” in general paramaters section?
Solved2.16K views1st September 2023active alarm console alarm
Bruno Sousa [DevOps Member]669 31st August 2023 0 Comments
Hello
Can you please clarity what is the meaning of [Element alarm state] parameter in the "general parameters" section of an Alarm template?
Thank you.
Best regards
Bruno Sousa
Bruno Sousa [DevOps Member] Selected answer as best 1st September 2023
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 31st August 2023 0 Comments
Hi Bruno,
Represents the current alarm state at element level. It is available in the page 'General Parameters':
You could enable monitoring on this parameter for example to trigger a specific alarm severity when the element goes into timeout or error state.
