What is the “max-repetitions field in the BulkPDU” for? In a Qaction using NT_SNMP_GET(295)
Solved1.79K views11th July 2023
Carlos Morales [SLC] [DevOps Member]168 27th October 2020 0 Comments
In an implementation through Qaction of SNMP polling, there is a value in the configuration array (ElementInfo), I would like to know what this refers to.
"elementInfo[13]: (int) Specifies the value for the max-repetitions field in the BulkPDU"
Supported since Dataminer 10.0.2
Jens Vandewalle [SLC] [DevOps Advocate]10.00K Posted 27th October 2020 0 Comments
Hi Carlos,
You can find more information in RFC3416 section 4.2.3.
