What is the difference between a NuGet Pacakge Solution and Project
Solved2.02K views22nd August 2023DataMiner Integration Studio NuGet Visual Studio
Michiel Saelen [SLC] [DevOps Advocate]6.55K 22nd August 2023 0 Comments
When creating a new project in Visual Studio you have the option to select 'DataMiner NuGet Package Project' and 'DataMiner NuGet Package Solution' (see screenshot). When should you use one or the other?
Michiel Saelen [SLC] [DevOps Advocate] Selected answer as best 22nd August 2023
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 22nd August 2023 0 Comments
Hi Michiel
If you start a new solution, they you need to take the Solution template. This will already include a project with the correct settings. If you want to add an extra project (meant to be another NuGet package), then you can use the Project template. This will add the project to the solution with the same settings as the current project.
