What is syntax for hyperlink for using POLLINGIP placeholder.
Solved766 views11th September 2025hyperlink hyperlinks
Matija Kos [DevOps Advocate]72 18th April 2025 0 Comments
Is this ok: <HyperLink id="4"
version="2"
name="Otvori web GUI"
menu="root"
type="url"
alarmColumn="true">
http://[POLLINGIP] </HyperLink>
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 18th April 2025 0 Comments
Hi Matija,
This syntax looks good. More information about syntax of hyperlinks can be found here Hyperlinks.xml | DataMiner Docs.
